Andy Cox
I'm not sure fitting a switch is a good idea. I'm guessing these heaters are no different to the Ebers, in that when you turn it off at the control unit, the heater goes through a pre determined cool down cycle which is necessary to prevent the unit overheating.
If your switch is inadvertently turned off whilst the heater is running then it won't get the chance to cool down and you'll cook it.
I'm sure the Eber installation manual says to connect the power supply cables directly to the battery. Also, make sure you use a good size cable, as under size cables will reduce the voltage at the unit which is one of the most common heater faults as they are quite voltage sensitive.
Andy
Andy
