roughbert
There seems to be a lot of choice in life jackets these days. Can anyone suggest a good cheap 'un, or maybe a cheap one that is not to be avoided. Thanks!
What sort of life jacket do you want?There seems to be a lot of choice in life jackets these days. Can anyone suggest a good cheap 'un, or maybe a cheap one that is not to be avoided. Thanks!
I find it a bit amazing that the only answers seem to suggest gas inflatable LJs are the only ones.
The vest type will not keep your head out of the water [...] More floatation on the front and behind the neck give the self righting head out function but are then uncomfortable to wear long term.
Now it depends on what you want or are required to have.
I find it a bit amazing that the only answers seem to suggest gas inflatable LJs are the only ones. Now it depends on what you want or are required to have. For choice I go for buoyancy vests in foam. Thse are pretty much indestructable. Can help keep you warm around the torso and provide buoyancy with no action from the victim. The vest type will not keep your head out of the water but on the other hand enable you to swim and hopefully get back on the boat unaided. More floatation on the front and behind the neck give the self righting head out function but are then uncomfortable to wear long term.
I have a couple of new inflatables made obligatory for sail training but for choice I wear and give my crew buoyancy vests. Worst problem is tha they forget to take them off when they home. Especially if it is cold. Incidentally my own and favourite is home made with foam filling from hiking mats. yes I have done some swimming in it. But I only give the customers commercially made ones. Of course you cna be a lot more confident buying foam LJs because you can see the condition. olewill
Problem with foam filled/'rigid' vests, is when entering the water from a height.
To be fair, you're unlikely to enter the water from a great height, especially deliberately and vertically, from a yacht.
Even from a metre or so, can still hurt if done incorrectly.
When I read this a little bell rang. I'm pretty sure that 50 years ago when lifejackets were made of canvas and cork I was instructed thus. A little research revealed that this crutch strap business is serious indeed, people have died in recent years. Here's a great lifejacket resource: http://ftp.rta.nato.int/public//PubFullText/RTO/AG/RTO-AG-HFM-152///AG-HFM-152-09B.pdfProblem with foam filled/'rigid' vests, is when entering the water from a height. Unless the wearer has been trained in crossing arms to prevent the LJ being forced up under their chin, injury can occur. Can I also emphasise the use of crutch straps, which continue to be ignored by people wearing LJ's.
In this part of the world nowadays you basically never see foam lifejackets on yachts except for small children.
In the past, when lifejackets were only worn in genuinely heavy weather and for abandoning ship, you would sometimes find a charter boat kitted out with all foam, on the grounds that nobody was ever really expected to wear them and a locker full of unused foam jackets required no maintenance from the owner or charter company. But these days, when people tend to wear lifejackets more readily and in some cases all the time, it's invariably gas.
This is probably why nobody here uses them on seagoing yachts.
Going into the water in the Channel, with lots of clothing, boots, and waterproofs, a 50N buoyancy aid is really not what you want. A proper lifejacket made of foam is an embuggerance to wear (every time I sailed on Stavros we had to put them on as part of the Abandon Ship drill - no way it's practical to wear the things full time).
People do, of course, wear foam vests in dinghies. In racing dayboats, where you don't expect to fall in, but are generally in fairly protected waters, you tend to see a mixture of foam buoyancy aids and gas lifejackets.
No requirement here, if it's your own boat (and, I think, under 24m). You could go to sea with a plastic bag to blow into and then hold onto, but it wouldn't be very clever.
I often wear infatable LJs and often wonder just how long it would take me or worse a student to find the toggle and inflate the LJ. Asuming he is not injured (unconscious). You have to tuck it away to avoid inadvertant infaltion.
Automatic inflation, either hydrostatic or dissolving-tablet, is pretty common here.
I don't generally hide the toggle even on an auto jacket, and I certainly wouldn't on a manual. The pear-shaped knob is pretty good at not getting caught on stuff, and the lanyard is very short so it doesn't dangle where it shouldn't. My new Kru Sport Pro jacket also has an extra velcro tab to hold it out of the way and prevent any light tugs setting it off.
FWIW the missus is somewhat distrustful of auto LJ's and prefers wearing her well tested dinghy 50N bouyancy aid when transferring between tender and yacht though does wear an inflatable once on board the yacht for the additional freedom of movement. The dinghy aids dont take up a lot of stowage and potentially saves having to buy a rearm kit. So far its only me that's fallen in though !
