Minerva
Thats it - I'm going to launch a new Ostar. Advertise it as strictly run under the "same conditions" as the original Blondie Haslar race, but the boats must be carbon fibre foiling 25ft catamarans.
And charge £10k to enter. You're on a winner ?Thats it - I'm going to launch a new Ostar. Advertise it as strictly run under the "same conditions" as the original Blondie Haslar race, but the boats must be carbon fibre foiling 25ft catamarans.![]()
There were a lot more than 4 starters in the original race. And of the GRP ones, two I believe were bilge keelers - though neither made it to the Southern Ocean. One still sits ashore in Loch Laxford, still owned by its original skipper.Fair enough. It seems very revisionist to me; a yacht that one of the original competitors could have bought at the time is excluded, yet one that first saw the light of day 12 years later is ok.
FWIW, these rules would exclude 3 of the 4 original entrants. Bernard Moitessier’s Joshua (40 ft steel hull), Bill King’s Galway Blazer, (wood construction, fin and skeg),and Donald Crowhurst’s Teignmouth electron (41ft trimaran, wood IIRC).
Why, therefore, is it called the Golden Globe Challenge ?
Those are the rules, not use complaining about it. I can understand the rules somewhat. However if any boat from before the 1988 was permitted I would like the SHE 36Fair enough. It seems very revisionist to me; a yacht that one of the original competitors could have bought at the time is excluded, yet one that first saw the light of day 12 years later is ok.
WOT?? Not an Anderson 22?They are all wrong … they need a bilge keel Corribiee MK2. Would increase the market value of mine![]()
There doesn't appear to be a wide availability of used Vancouver 34. You have experience of this boat? How would you expect it to perform against the Rustler and Biscay?
The Vancouver 34 appears to have a shallow draft, less than 5 feet. Is that deep enough for crossing stormy oceans?
How would you rate it's chances in a round the world race against the 36 footers, Rustler, Biscay, Gaia etc?As an ex owner of a V34C
Were you happy with wheel steering. Did converting to a tiller cross your mind?I used to regularly sail against a Rustler, there was nothing to choose between them.
The Joint Services Adventurous Sail Traing Centre .....mouthful...?.operated a number of Victoria 34's. I sailed a few of them when the y were first introduced. Tough as old boots. The yachts. And the crews!!More than happy, I had a tiller steered V27 for several years and sail several V32s with a tiller but I would never have thought about converting the 34 to tiller I believe a few were made for the joint services though and remember seeing one for sale but I see no particular advantage in fact it would be a disadvantage in not being able to install the below deck Whitlock / Lewmar motor for auto pilot under the pedestal, you would have to use a ram connected to the quadrant which imo is inferior or the even worse option of connecting one to the tiller itself.
