Golden Globe Race - Entering the Orca Zone!
dunedin
3 Feb 2004
Fair enough. It seems very revisionist to me; a yacht that one of the original competitors could have bought at the time is excluded, yet one that first saw the light of day 12 years later is ok.
FWIW, these rules would exclude 3 of the 4 original entrants. Bernard Moitessier’s Joshua (40 ft steel hull), Bill King’s Galway Blazer, (wood construction, fin and skeg),and Donald Crowhurst’s Teignmouth electron (41ft trimaran, wood IIRC).
Why, therefore, is it called the Golden Globe Challenge ?
There were a lot more than 4 starters in the original race. And of the GRP ones, two I believe were bilge keelers - though neither made it to the Southern Ocean. One still sits ashore in Loch Laxford, still owned by its original skipper.
Perhaps none of the original entrants would qualify for these bizarre rules
Colum
8 Aug 2021
Those are the rules, not use complaining about it. I can understand the rules somewhat. However if any boat from before the 1988 was permitted I would like the SHE 36
Colum
8 Aug 2021
There doesn't appear to be a wide availability of used Vancouver 34. You have experience of this boat? How would you expect it to perform against the Rustler and Biscay?
SaltyC
15 Feb 2020
Yorkshire
They are all wrong … they need a bilge keel Corribiee MK2. Would increase the market value of mine :)
WOT?? Not an Anderson 22?
Seriously, Vancouver 34 vs Rustler 36. I would go with the former, designed as cutter, built like a proverbial shed in the garden.
BUT Rustler is the choice of those who 'know'.
Perhaps a 34 Pilothouse and go in comfort? :)
E39mad
15 Mar 2011
Nr Macclesfield
The Vancouver 32 or 34 is similar in displacement and internal volume to a Rustler 36. Not sailed either the Rustler or the Biscay to make a direct comparison but I think they are not far apart. I have sailed a 32 and 34 in varying conditions including 30 knots wind over tide going out through the Needles. It is an extremely reassuring boat and beautifully balanced which means less work for any self steering gear.
Yachting Monthly did a test on about 6 or 8 similar boats in 1994 and the Vancouver and Rustler came out top. What is different is that the Vancouver is designed as a cutter from the outset and it is probably the best rigged out of any of them with two separate backstays, separate intermediates fore and aft and separate lowers as standard.
Colum
8 Aug 2021
The Vancouver 34 appears to have a shallow draft, less than 5 feet. Is that deep enough for crossing stormy oceans?
Fr J Hackett
26 Dec 2001
Saou
As an ex owner of a V34C who crossed Biscay in it 4 times including a 36 hr spell of 40 kits plus fortunately up the chuff I can tell you they cope very well especially fitted with a Hydrovane self steering gear.
E39mad
15 Mar 2011
Nr Macclesfield
There were 62 V32's built and about 45 Vancouver 34's including the Pilots - many of which have crossed oceans numerous times.
The 27 and 28 have even less draft (4'3") and are renowned as the sub 30 foot pocket cruiser to sail around the world in. Recently Sea Bear is in Yachting Monthly and Fathom is on Youtube. These boats have doing it successfully since the early 1980's.
Fr J Hackett
26 Dec 2001
Saou
Were you happy with wheel steering. Did converting to a tiller cross your mind?
More than happy, I had a tiller steered V27 for several years and sail several V32s with a tiller but I would never have thought about converting the 34 to tiller I believe a few were made for the joint services though and remember seeing one for sale but I see no particular advantage in fact it would be a disadvantage in not being able to install the below deck Whitlock / Lewmar motor for auto pilot under the pedestal, you would have to use a ram connected to the quadrant which imo is inferior or the even worse option of connecting one to the tiller itself.
capnsensible
15 Mar 2007
Atlantic
The Joint Services Adventurous Sail Traing Centre .....mouthful...?.operated a number of Victoria 34's. I sailed a few of them when the y were first introduced. Tough as old boots. The yachts. And the crews!!
E39mad
15 Mar 2011
Nr Macclesfield
The Vancouver 34 is so well balanced you could invariably walk to the foredeck and back and the boat would not veer off track without any steering aid on (autopilot or windvane). The wheel steering was finger light even with the gunnels awash with two fingers on the wheel spoke was all that's needed. I don't think many boats including the Rustler are as well balanced. I only remember one being built with a tiller.
