Danny Jo
OK, expressed in those terms the lee bowing effect is mediated through an increase in "true" wind speed (as compared with the same wind blowing over slack water) which brings the apparent wind aft and allows you to sail closer to the wind.What you are reffering to is the difference between true wind and ground wind. Ground wind is almost irrelavent to sailing, it is the true wind (which as you rightly point out is affected by the tide) which is what the boat sees. I have never heard of anyone referencing tacking angles to ground wind, only ever true wind.
This is an effect we see racing, especially with cross currents. As the current builds (typically as you sail out into deep water) you will see a predictable wind shift. This is however not effecting the performance of the boat.
