webcraft
I want to glue cord carpet onto the hull to line the forepeak.
What glue should I use?
- W
- W
The OP mentions 'cord carpet' which sounds to me to be the type of material sold for lining camper vans.Normally hull liners are NOT actually carpet, but a product like Frontrunner that is thin and conform better. Carpet is asking for perminant mildew, because it holds moisture and cannot be easily cleaned.
Frontrunner
It is applied with spray contact cement. 3M Super 77 is common, and now Gorilla makes a product.
I read that as "a 5 or 6 year-old can do the job" which impressed me enormously. Precocious, your kids.I have a 5 or 6 year old can and it still does the job.
Might gluing some velcro 'loop' in the forepeak, then gluing some velcro 'hook' onto the carpet at the suitable spots, also be a solution?
Tight corners .....I read that as "a 5 or 6 year-old can do the job" which impressed me enormously. Precocious, your kids.
When you peel it off it usually brings the tabs attached to the grp off as well. The carpet can droop between them in use. Not impressed.I was thinking of trying this as I want to be able to take carpet up relatively easily to clean it.
You can get self adhesive Velcro so will see if it works.
eBay search for 4 way stretch carpet will find the correct high temp adhesive. That is the only product to use in boat. Exterior PVA glue is fine for ply panels. The 4 way carpet is fantastic stuff to use too. Very conformable, neat and if from a reputable supplier, non mould (I hope)
