Pagetslady
Never sure whether Dinghy or Dingy is correct, but any way how do you get your outboard onto your dingy when it is launched. I have my dinghy on davits on the transom of my Westerly Corsair and the transom is around 4ft out of the water. At the moment I use one of the Davits and lower the motor into the water, then get aboard the dingy lift it onto the transom of the dinghy, to remove I attach the motor to the davit rope lift the motor off the dingy whilst hanging onto the end of the lifting rope climb back on board and raise it until I can lift it onto a bracket on the push pit. Its had a few dunkings but still gives great service, I have a safety line attached all the time. My davits are fine for lifting the dingy but I think they are over pressed with the motor attached.
It has struck me that one of these brackets that smaller yachts use when they dont have an inboard so use an outboard bracket that lifts the engine clear of the water when sailing and drops it down into the water when they need to motor, what is the range between up and down, If I had a bracket on the transom which would lift it well clear of the water but would drop it into the water sufficient to use as an auxiliary when needed but could also be lifted from the bracket and put onto the dingy from the lower position, when I am on board the dingy.
Mike
Mike
