webcraft
Anyone know anyone?
- W
Anyone know anyone?
- W
Order one on the internet and do it yourself?
Buy another dinghy for £80?
You can still buy A4 valves AFAIK, so like-for-like should be possible? If the valve is leaking have you tried either cleaning the diaphragm or in the last resort replacing it? changing the whole valve is definitely the nuclear option.
The last time one of mine started leaking a bit I gave it a good spray inside with some silicone spray. It seemed to wash it out and lubricated it and left a residue that assisted with it sealing afterwards. It was on my rib and so I did all 4 of the valves at the same time.
That was a year ago and its not leaked since.
You haven't said if it's just a slight leak problem or something more major (or I didn't see it) but if its a leak, try the spray first. It may save you an awkward job.
Is there a way you can connect the two chambers internally and simply seal the faulty valve with "Faulty Valve Sealer"? Then inflate the dinghy from the one valve.
OK, you'd need to make a couple of slits in the dinghy to get at whatever separates the two chambers, which would then need repaired, but that might be easier than replacing the valve.
I suppose if a repair leaks, or the non-faulty valve leaks, you might go glug-glug...
