Birdseye
X tachts are like Readers Digest. Once on their email list you are there for ever.
Better than some 90s AWBs which had the main on a winch well out of reach from the helm, like 9ft forward of the wheel.
[...] And why is it called German when we dont give a nationality to other bits if the boat?
Yes, exactly like my current boat, although in practice it is less of a problem than imagined, mainly because it is not a boat that requires constant trimming and dumping of main etc. I have singlehanded for years with it like that and being in mast it is quite easy to fine tune the mainsail area to minimise the need for instant access to the mainsheet. Autopilot helps of course as one is not then tied to the helm.
However have just ordered a new boat that has the main sheet just in front of the binnacle and primary winches aft near the helm. Smaller boat but overall sail area not much smaller at 51 sqm compared with 58, but much smaller genoa at 22 instead of 32. All part of keeping up with advancing age and making life easier.
I am not sure why it is so important to have controls near the helm. If anything they would be on the way. Let's be realistic.
If we are racing, we will have one helmsman and crew. If we are cruising ... well who cruises even single handed without an autopilot?
What boat have you ordered?
+1Lots of people prefer to steer, to get the best out of the boat.
In close quarters situations, you need to be steering, and when the gust hits you as you sail into clear air, you may want to ease the sheet.
If you don't need to ease the sheet now and then, the main simply isn't big enough...
I don't often sail single handed, but often two up, and the other person is not going to be standing by the sheet full time.
If you have the sheets to hand, it becomes possible to leave and pick up the mooring under sail etc.
I regard an autohelm as an option which I can choose to use, not an essential.
If other people want to sail differently that's fine by me though.
One important reason is if you have to bear off suddenly, to avoid another boat, floating obstruction or pot buoy.
Need to be at helm to bear off - and unless can ease mainsail quickly likely to just accelerate and not bear away, risking hitting the object or boat trying to avoid
Also, it reduces the amount of string in the cockpit, compared to a multipart sheet and maybe a fine tuner as well.
The German mainsheet system with winches takes a reasonable amount of skill to use, especially on gybes. One advantage is it's fast to release in terms of less line to run. The drawback is you have to be ready to release, if you want to do it quickly,with the mainsheet uncleated or off the self tailer. It can be slower to bring in unless crew are helping with sweating the sheet and grinding both winches.
I know the system you mean, still seen on big boats with really fancy blocks on the traveller.Not sure if ours is strictly a german mainsheet system as it doesn't go via the mast - centre cockpit, traveller on afterdeck just behind helm, double ended sheet going to primary winches - I can manhandle up to about a low F4 after which I need to use the winch. Which makes gybing great fun when its blowing a bit: have to sheet in main on the lazy primary, clutch it off, whip the mainsheet off the lazy winch, put the lazy genny sheet on the lazy winch, jam off the working genny sheet and remove it from the working winch, put the mainsheet on the working winch so I am ready to ease the main, gybe the main, clutch off the main, put the genny sheet back on the working winch, ease and gybe the genny then put the mainsheet back on the new lazy winch. We're usually two up, which often means I am doing manouevres single handed. We tend to tack right round a lot! Really need a couple of dedicated mainsheet winches, in which case it would be a great system, but there is nowhere obvious or ergonomically efficient to put them. I am guessing that doubling up the purchase by usiing a double block on the boom and traveller car to reduce the times I have to use the winches to gybe wouldn't work on this system (purely on the basis that I haven't seen one - I tend to get brainfreeze when trying to visualise purchases).
ohmaggie - any chance of a photo (of your mainsheet system!). We have a centre cockpit yacht with the traveller on the afterdeck, and I am looking at options to replace the current system. We have a pair of spinnaker winches mounted towards the rear of the cockpit that would work well with your system.
