Stemar
I would think it's only common sense to fit a CO detector on any boat with anything that burns some sort of fossil fuel. They aren't dear and they do save lives.
Boat was fitted with an eber when bought but not been working for some years,which took the air in from the foot of the quarter berth ,heated it and expelled it via ducting too main cabin.Where on a seagoing boat would you intake fresh air thats not salty?
Why not pop round when I try it out in the workshop. Due a beer and a chat.Can I pop along to see it when you've finished Trev. I can then learn from you mistaks!!!
A minor advantage of a SWMBO who smokes is an easy ability to test it.
All the advice I have seen is that CO monitors should be placed high, not low, as CO is slightly lighter than air. Why would you have/need a CO2 monitor? I have a CO monitor placed high, an LPG monitor placed low, and a heat/smoke detector.
Er - I do have windows and other vents without the heater. I am not about to close all or those !And you're wanting recirculate contaminated damp air, rather than let fresh air drive it out?
CO is slightly lighter than air. ... The difference is so slight that CO is found to evenly distribute itself indoors. It is worth mentioning that CO indoors is usually generated from incomplete combustion (heat source) and therefore traveling in a warm air stream. Warm air is more buoyant and does rise but when it cools it will sink!
Fuel Combustion and Carbon Dioxide. ... The mixture burns when ignited, giving off large amounts of energy and leaving behind water vapor, carbon dioxide and other gases as waste products.
Carbon dioxide (chemical formula CO2) is a colorless gas with a density about 60% higher than that of dry air.
As I stated when air cools the co and co2 will disperse if you have you engine as I do in the bilges and if you have your heater there circulating air I would advise gas detectors , this is why you gas canisters must have a low vent to the outside of the boat in case of gas leakage.
OFC have smoke detectors in every room and CO detectors near and high for internal fuel sources , cooker heater ,etc
Hi all,
Where are people buying resonable priced exhaust skin fittings for the chinese heaters. Some of the ones I am seeing are nearly as expensive as the heater. Also, I would have assumed they get placed on the stern but have read some comments about not putting them there?
Hi all,
