2 Oct 2023 #1 R rigpigpaul Member Joined 5 Aug 2004 Messages 244 Location Merseyside & Yalikavak Visit site Hi All. I have a few small chips in my gelcoat. I can see the fibre glass mat. What is the best material to do the repair. I only need small amount. TIA RPP
2 Oct 2023 #2 Refueler Well-known member Joined 13 Sep 2008 Messages 17,812 Location Far away from hooray henrys Visit site You can buy Gel Coat repair in tubes or pots .... I use Occulati from Italy ..... Plastic Padding in UK used to do a Marine Gel Coat in a yellow tube. You can also get pigment to add to Gel Coat to create match to existing. Clean thoroughly area .... I use Oven Cleaner and then seriously rinse off with fresh water. let dry ... Mix Gel ... using a lollypop stick or small filler spatula ... apply gel slightly proud of chip. Let cure. Sand back till flush - then finish with ultra fine grade ... if colour is OK - polish ... I have a few chips out of my boat ... which is white Gel then painted red. You can just see the biggest chip halfway between the fenders ... I will fill with standard white Gel Coat - then sand back ... paint to match ... polish. Last edited: 2 Oct 2023
