Marine Reflections
The reason I asked for some pics was just to determine the depth of the scratches and amount.
Rule of thumb is if you can catch your nail on them, then add gel.
Think I have a tin of 9003 flowcoat that's never going to get used as I never use pre-mixed.
Pre-mixed is great for projects, but is not great for repairs due to the lack of pigment, repairs need to be at full 10% pigment or you will just get a see-through repair.
Personally I wouldn't go down the peel ply route (unless you were re-finishing the area), nor would I use flowcoat, gelcoat is so easy to cure with other methods, but a pain to apply more with decent adhesion due to wax, even after sanding.
If you are indeed thinking of brushing gelcoat or flowcoat onto the area then sanding down anything above the actual surface and hoping this fills the scratches, it's going to be a disappointing and messy day.
Could it be possible (as you say they are too deep for polish, but not deep enough for filler) that they could wet sand out?
How many scratches are we talking?
Pics would help advise, appreciate you might not be carrying them around with you.
