demonboy
I have a Hurth HBW 250, which has fresh oil in it. On our last couple of trips (i.e. since leaving the shipyard after a year) I noticed that it is leaking and I think it is coming from the lever. I've read that this is common, easy to fix and can be done in situ, but the problem is I don't have spares (other than the internal plates). You can see the lever section highlighted in this illustration:
In another forum I read that this would only take 40 minutes:
Remove the shift lever off the shaft.
Remove the 4 nuts retaining the shift cable mounting plate and the plate over the shaft seal. Carefully pry or tap the plate to break the seal.
Replace he shaft seal.
Sounds easy enough but before I take it apart what I am trying to work out is:
a) which number on the diagram is the shaft seal (I'm guessing 8)
b) is this likely to be an O ring or a standard water seal (I have a box of O rings with one that may fit)
c) i am assuming that by shaft seal he is not talking about the plate gasket
If this is a specific spare part is there anything I can use in the meantime?
I can find loads of service kits for Hurth gearboxes but nothing about parts for this seal.
