Gas safety taken too lightly
KREW2
20 Jan 2005
Dorset
A recent thread about gas safety spurred me on to install a bubble leak tester, mainly because the copper pipe, where visible looked tired. After installation it showed a leak in the system, in order to narrow it down, I checked the isolating gas tap beneath the cooker for leaks, all seemed good so I isolated the cooker. The tester was still showing a leak, so I checked the connection down side of the tester, all good.
Bugger! this meant the leak was in the copper tube which runs into the bowels of the boat. I decided to take the plunge and rip it out, this involved cutting a huge hole in the back cabin, removing the water pump from under the cooker well, and pulling the old pipe out with a mousing line attached. Not an easy job it took nearly 2 hours, but here is what I found.
VicS
13 Jul 2002
That's bad.
Blue is the colour code for water. Yellow tape should have been used on gas pipe!
pvb
UK East Coast
To be fair they had put a bit of plastic metal, or some other gunk on it as well
But from what you've said about the difficulty of getting the pipe out, it sounds as if the installer must have patched the pipe before installing it!
DanTribe
8 Jan 2002
Essex
Horrendous, but if you hadn't found it you you may not have known anything about it! Just another unexplained explosion.
That's a few hours very well spent.
rob2
23 Aug 2005
Hampshire UK
Glad you've got that sorted. The thing that worries me about gas is the number of people who have bought an item of safety equipment and then don't give the issue another thought.
Rob
KREW2
20 Jan 2005
Dorset
No, I'm pretty sure the pipe was the original installed by Westerly, the boat was built around it, hence the difficulty getting it out. So, pulling through the new pipe is going to be a challenge, but we'll see.
The tape in the picture was about 18 inches back from where it was connected to the cooker gas cut off tap, I only noticed it when I shone a torch up between the cooker well and the hull. It was only accessible, through the hole that the water pump fits into, so, although doable it would have been a tricky job to get the tape on with one hand.
DavidGrieves
13 Aug 2001
West Cumbria, Cumbria
www.wsandba.co.uk
Maybe it's a Westerly thing... I replaced the gas pipe on my GK29, the old one was just lying in the bilges not clipped or fastened anywhere. I re-routed a new pipe and fastened it down so it can't move.
Many years ago whilst working for a council maintenance contractor I pulled up a floor board in a kitchen and realised I'd pulled a nail out of a gas pipe which caused a leak. The nail had probably been in there about 30+ years. I bet there are loads of gas explosions waiting to happen...
VicS
13 Jul 2002
But now Corgi has been replaced by Gas Safe then NOBODY can get yellow tape :(
Electricians can get it... used to identify the yellow phase on three phase systems.
Now someone will come along and tell me they have changed the colours on three phase systems !
