Seastoke
Ok hob and oven replacement are they piped solid in 8 mm or do you put short length of rubber to each one please help its santas prez
to swimbow
Ok hob and oven replacement are they piped solid in 8 mm or do you put short length of rubber to each one please help its santas prezto swimbow
Stumbeled upon this page - see near bottom
http://samsails.blogspot.dk/2010/10/how-safe-is-your-yachts-gas-system-part_5364.html
For your own safety and of others around you it should be installed by a gas safe registered engineer who is up to date with the regulations and knows exactly what pipe size and material to use. There's too many dangerous diy gas jobs done that just shouldn't be allowed. It will also need to be tested and commissioned correctly.
If you don't want it gimballed, use solid pipe - it saves a join.
I'm not so sure thats best practice on a mobo.
Vibrations can weaken the joints , spiral loop of pipe can help but reinforced steel braided would be better IMHO.
+1 It doesn't cost too much. When I had mine done it was some senior engineer from the Gas Company who fancied an afternoon on a boat.
They use proper armoured (if that's the right word) rubber tubing for the flexible connection.
