Pete735
I've fitted a gas locker and associated pipework to comply with current regulations, but am left with one problem. Stern is a sugar scoop and angled at 60 degrees to horizontal where drain needs to be. I bought a standard straight plastic skin fitting (type that has both 19mm and 25mm hose tail - I'm using 25mm) and cut hole in the stern only to realise that the plastic pipe from fitting to the gas locker drain, angles downwards prior to going upwards to the actual gas locker. As such this will fill with rain water over time and block the pipe.
I intend having the system inspected and to hopefully get the necessary certification, but clearly not with this setup.
I've made up 2 angled pieces of tube so that the skin fitting comes out horizontally, but there is not enough thread on the fitting to put the locking nut on, so that's out. alternatively, I could use just one angled piece of tube and sikaflex the whole assembly in, but my preferred choice is to use a lock nut
I've looked around all the usual sites trying to find a 25mm skin fitting that is angled at 45 degrees (in white plastic to match other stern fittings), but come up with nothing.
Only option I can think of currently is having one made in stainless , but I would prefer the white plastic option for neatness.
I cannot believe I'm the only person ever to come across this issue, just wondered if anyone has used/found an angled skin fitting - 90 degrees are available, but not suitable in this situation - or devised another option?
Thanks for any help offered.
