SimonP85
We recently asked a local marine gas engineer to disconnect the cooker on the boat so that we could remove it from the space to allow us to give the area a long overdue deep clean. On reconnecting and running a pressure test the engineer found a drop in pressure which he traced back to a leaking and superfluous isolation valve. This valve was not immediately visible but still accessible to service and replace.
The leaking isolation valve has now been replaced with a standard compression joint and the system pressure is good, but the boat has failed the safety check due to: 1) No isolation valve at the cooker end 2) New compression joint (replacing leaking isolation valve) that serves no purpose and as such is necessary.
The engineer is now suggesting the entire gas installation needs to be redone in order to comply with the regulations, in particular to ensure one seamless run of copper pipe from the gas locker to cooker isolation valve.
Can anyone comment on the above? From looking at the Boat Safety Scheme guide here the advice on compression joints seems to be that they are allowed as long as they are accessible and serviceable, which this is. Does the fact that it's an unnecessary joint (not providing a T or similar) mean that it's not acceptable? 7.10.3/R suggests that unused connection points are ok provided they are suitably capped off so I'm not sure why a simple straight connection wouldn't be?
Lastly it's been suggested that an isolation valve needs to be fitted at the cooker end. This has been recommended previously by the surveyor but looking at the guide above regulation 7.11.1/R seems to imply that for an installation of one appliance connected by hose the valve at the cylinder is sufficient - but is this as installation of hose only, not bottle-hose-pipe-hose-cooker?
Any advice would be much appreciated.
https://www.boatsafetyscheme.org/media/164540/bss guide chap7.pdf
