cpedw
Our boat has two flexible LP gas hoses which look like original (2001) equipment. Time to replace. The old ones are GOK manufacture with appropriate fittings crimped on.
The originals have 3 different fittings - 1 LH thread for the camping gas regulator, 2 female compression fittings to the copper pipe and a male compression fitting onto the cooker. It's all 8mm.
Can anyone point me to a source of replacement hoses with the fittings on? I found this previous thread http://www.ybw.com/forums/showthrea...t-GOK-flexible-LPG-gas-hoses-for-our-Jeanneau but the link to parts4caravans is dead and I can't find what I want on Socal's website.
Alternatively, I could try to dismantle the old pipes to re-use the metalwork with new hose and hose clips.
Or I can saw off the compression fittings on the copper pipe and fit hose directly. I will need the fitting for the regulator though. Not sure if there's enough plain pipe on the cooker to allow cutting off the fitting then clamping hose to the remaining pipe. How easy is it to remove the olive without damaging the pipe it's on?
To reassure the nervous (?) I have twice successfully replumbed hose previously, but it was just hose onto plain pipe or hose tails with hose clips.
Which way to go?
Derek
Which way to go?
Derek
