Ian_Rob
I need to replace two gas hoses. Are braided hoses preferable (mandatory)? Is it worth adding a bubble detector?
Bubble testers are fitted simply because the examiners then do not need to be gas safe registered to do boat inspections. They need not open the gas system at a test nipple to do a drop test which would involve them in certifying that it was gas tight again. Unless registered they are not qualified.If you mean external metal braid, definitely not. It's imposible to inspect the rubber which is the important bit.
High pressure, Low pressure or both?I need to replace two gas hoses
No restriction on use of braided hose - in fact recommended in many situations such as swinging cookers where the hose might be subject to abrasion. If you replace hose by its due date there should not be a problem with deterioration of the rubber.If you mean external metal braid, definitely not. It's imposible to inspect the rubber which is the important bit.
Low Pressure. Campingaz.High pressure, Low pressure or both?
Yes, it seems to me that as long as braided hoses are replaced by their due date then they are probably preferable. Our cooker is gimballed.No restriction on use of braided hose - in fact recommended in many situations such as swinging cookers where the hose might be subject to abrasion. If you replace hose by its due date there should not be a problem with deterioration of the rubber.
