MikeBz
How do they work then? I mean the magnetic strip things which purport to tell you how much is left in the cylinder.
I'm guessing that since they only 'work' when you're using gas it must be something to do with the cylinder cooling and the bit below the 'waterline' (liquid level) cooling more quickly than the bit above the level (higher heat capacity of the liquid). Maybe.
Presumably it should be placed at the bottom of the cylinder?
Mike
Mike
