Garmin to Raymarine
baily
30 Apr 2006
Hi can any body help please I have a Garmin 720 plotter with NMA0183 data output is this compatible with a Raymarine RL80c the gps in the menu states WGS84 will these work together or do I require an antenna for the Raymarine ?
PaulRainbow
16 May 2016
Suffolk
WGS84 is nothing to do with NMEA. If you connect the NMEA out on the Garmin to the NMEA in on the Raymarine it should share GPS data. Disconnect the Raymarine GPS from the plotter and make sure they are both set to the same baud rates.
