Garmin Homeport
westward
17 Jul 2017
I have two Garmin GPSMAP 4008 plotters on my boat. Up till now I have used the Garmin Homeport app on a PC to do route planning. As Homeport is discontinued, does anyone have a suggestion for how to do route planning? The only way I have of communicating with the GPSMAPs is by SD card. The Garmin app Active Captain only runs on phone operating systems and I don't know of any phones which take SD cards. In any case, I can't imagine doing an ocean route plan on the tiny screen of a phone.
LiftyK
3 Sep 2015
I am not familiar with your specific plotter but the way that ActiveCaptain generally works is that you connect your phone/tablet to the plotter and register your maps. The phone then gets its maps wirelessly. I don’t know if this is from Garmin online or directly from your plotter. Either way, you do not need an SD card reader on yourr phone.
Graham376
15 Apr 2018
Our Samsungs take micro SD cards which slip into a full size SD adaptor.
Refueler
13 Sep 2008
Far away from hooray henrys
The only time I use an SD card with Active Capt is for updates, but most down loads I found can be without SD card ... rest of time transfers / comms are via WiFi ....
But I'm no expert on AC !! in fact I need to use it more to learn more about it ...
westward
17 Jul 2017
Do you use Active Captain? I understand that the only way it can output route files apart from by WiFi is through email. I guess you could write the email, open it, extract the files and copy them to the SD card. Do you think this would be possible on an Android tablet? I'm always being foiled by limitations on file transfer on my phone.
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
ActiveCaptain is not compatible with HomePort. HomePort is a display application for Garmin Charts.
p.s. My ancient plotter is going nowhere near the internet. It has a SD card to pass data from and to the PC. One I can virus check.
LiftyK
3 Sep 2015
Indeed, but the question was about ActiveCaptain needing an SD card in a phone and I was responding to that question.
