galvanised chain plus nylon = rust
Gunfleet
1 Jan 2002
Orwell
Has anyone else noticed their anchor chain splice induces rust to the chain? My anchor chain is good quality but has rusted on the splice but nowhere else. Weird. I also have a good quality Japanese diver's knife which I put a nylon lanyard on. No rust anywhere except where the nylon lanyard touches. What is it?
cindersailor
30 Jan 2003
Edinburgh
I assume that this is due to the fact that nylon absorbs quite a bit of water, your chain/knife is therfore in long term contact with water where it is attached to the nylon providing a good environment for corrosion. Any other ideas?
Gunfleet
1 Jan 2002
Orwell
Definitely not friction. Maybe the constant presence of water, but it's quite a powerful effect. I'll try to post a photo when I can.
Ditto ... seen it on many a boat surveyed .... I tend to support the replies that water held in the joint is cause ...
Plus being Salt-water .... the salt will likely be precipitated out and remain behind even when dry.
Allan
17 Mar 2004
Lymington
Mine is just the same! I have put it down to moisture and/or salt. I also wondered if there could be anything acidic in the rope from it's manufacture.
Allan
Gunfleet
1 Jan 2002
Orwell
No stainless, Bill, unless you count the shackle right at the other end of the chain, attaching the anchor. It's a proper octoplait anchor splice, by the way. I don't really believe the effect is just salt and water. It just seems too strong.
Wunja
4 Feb 2007
The Netherlands
Its caused by the difference in potential between the zinc and the long chain molecules of the nylon.
The solution is to use a Nylon with a lower valency, reversing the potential current, or to install a sacrificial plastic anode.
/forums/images/graemlins/wink.gif
Vince.
GMac
20 Jun 2005
Rust by the end link is common as muck.
Could be something with the nylon. Is something to do with saltwater though as none of our rodes used in fresh water only do it. Combination of movement, salt and maybe something in the nylon is our best guess.
It is nothing to be afriad of untill it starts getting real intense. Then you had better cut the splice and the link it was around off and start again. Have a close look at the chain link under the splice, it may just spook you. It may not but I've seen more than a few that would.
Thistle
2 Oct 2004
Here
The sacrificial plastic is most effectively used by handing it to the chandlery staff on entry. It can be recovered before departure on provision of the correct 4-digit code. When used in this way for anodes, the process is sometimes referred to as "anodising".
Topcat47
2 Jun 2005
Solent, UK
Rust is an occupational hazard on a boat. I don't worry too much about my Anchor Chain because it rubs off and my annual examination has never shown significant reduction in chain thickness on any of the links. Iron Oxide is much less dense than steel so the rust always looks worse than it is if it's not been scraped off.
