jon
My galley sink base at the outlet is to be 180mm above the water line, and 500mm from the centre line in the heavy displacement sailing boat I am fitting out.
The max angle of heel before sea water enters the bowl is therefore calculated at best to be 20 degrees.
It seems to me I have three options with the waste outlet:
1) Outlet above water line. (Advantage no hole and seacock below waterline)
2) Outlet via seacock below water line. (Advantage seacock can be turned off in rough weather to prevent entry of sea water)
3) Pumped via loop to outlet well above water line. (Best? but expensive and more complicated)
I would appreciate any comments to my plumbing dilemma.
