Adonnante
Have any of you fellow forumites have one of these ?
Yes, I have carried a Gale Sail storm jib for 3 years, never used it in F5+ conditions but tested it in moderate breezes to ensure that as and when its needed I can rig it easily. We are fitted with a Profurl roller reefing system and usually set a laminated jib with a foam luff that is still sets well when rolled to heavy weather jib size. When rolled to storm jib size its flat and could not generate any lift but does allow the boat (12m cat) to be balanced and driven by a reefed main and rotating mast. If we have a strong wind leg we like to change to our heavy weather jib as this allows mast rotation when beating where the big jib fouls the diamonds but needs a strong crew to complete the change.
The storm jib is attached to a deck fixing just aft of the forestay by a strop to move the sail up above the roller reefing drum. The sail has a flap that wraps around the rolled jib ( the rolled jib sheets are left wrapped around the the jib but pulled down to the forestay deck fixing and lashed with a sail tie) and has a couple of 'D' rings that are attached to the tack strop. the flap is retained up the luff by piston hanks, five in our case. The head also has two 'D' rings that the halyard is tied to. We use a spinnaker halyard to hoist, but a second jib halyard would be better and give much less chance of chafe; now I think of it we have two spinnaker halyards so I could rig them both and only use the leeward one. In the moderate conditions that we have tested the sail hoisting hasn't been an issue, chafe on the rolled sail I would expect to be minimal and the halyard tension can be surprisingly light to give a good shape, the rounded leading edge results in an efficient looking shape, I'm sure some aerodynamic expert will correct me though.
In an ideal world I would like a removable inner forestay with a dedicated jib halyard for HWJ and storm jib. The modifications on my boat are about £6k and there would be no guarantee that the mast wouldn't be compromised. Our present arrangement is the best compromise that I can find. If anyone has any improvements based on practical experience on an improvement I am open to suggestions.
