furling genoa sheet length
smeaks
31 Aug 2003
tyneside
What is the ideal length for genoa sheets? Is there a rule of thumb with regard to boat length? I could just replace to the same length but i am interested in your inputs. Current are too long in that even fully unfurled the lazy sheet still has coils in the cockpit.
I like to have a turn or two round the furled sail and then enough for both sheets to come back to the cockpit and be securely cleated off. I also put a tie round the furled sail. That way I think I can be pretty sure that the sail won't unfurl accidently when I am away from the boat.
As a general rule headsail sheets are between 1 and 1.5 times boat length, depending on whether it's a small jib or a big genoa, but there are other variables. For instance, does the lazy sheet have to come forward to go around a babystay or not?
I would make sure the lazy sheet on your biggest genoa has at least enough slack to take a couple of turns on the winch.
Not only enough slack to allow turns on lazy winch ... but also enough to allow booming out of genny on pole. That makes quite a difference to slack in the sheets !
Boat length isn't a perfect factor for determining sheet lengths as it depends whether you have a centre cockpit or not, and what size genoa you have.
My preference is to ensure that I have enough sheet length to completely depower the genoa with the wind astern. In other words - can you let the genoa fly out to windward or not? I know I can usually roll the thing in, but I like to be prepared for when/if the furler jams.
The only way of knowing how long they need to be is to measure the boat and the genoa. 1.5 boat length might be ok...
Exactly ... part of the reason I mentioned poling out.
taking it to extreme ... you would need sheet length of cockpit belaying point to tack point ... + genny foot length ... then let fly will have genny flying dead ahead de-powered.
In practice though a sheet length could be a little less than that ... to allow sufficient "let-fly" and poling out.
[/ QUOTE ]Just realise I meant leeward - things don't fly out to windward!!
We all knew what you / I meant !!!! /forums/images/graemlins/wink.gif
