Furlex 100s - how much resistance to expect?
slawosz
26 Sep 2018
London
Hi,
I have Furlex 100s on my Sadler 25 and around 13-14 square meters genoa on it. I can furl and unfurl by hand, but I need to use quite a force. Without sail, the furler works rather lightly. Is it normal that I need to use force to operate furler with sail (I never use winch), or it indicates that I need to inspect further?
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Try lubricating it by injecting grease in the removable plugs. Give it a really good freshwater wash with a hose first and let dry.
We have a Furlex 100 on a Hartley 32 in Wellington NZ. Halyard tension is important, too much and it gets stiff to furl.
johnalison
14 Feb 2007
Essex
As well as easing the halyard, it helps to get into the habit of furling when turned away from the wind. I often see other boats struggling to furl their sail which is flapping for ages while I can furl mine in a fraction of the time just by bearing off and putting most of the sail behind the main.
Supertramp
18 Jul 2020
Halifax
Agree with all the comments plus check the alignment of the furling line as it leaves the drum. I have a 300 on about 40m square of sail and it furls by hand readily.
slawosz
26 Sep 2018
London
Thank you. I will investigate. The furling rope is old and tatty. Not sure about its leads. Also, halyard seems to be too tight. Also, I have probably nasty habit to furl in any course, will try now on the main shadow.
lustyd
27 Jul 2010
+1 for cleaning and greasing. They include grease with this model and I never used it, 7 years later it refused to furl. Dropped sail, clean, grease, worked like new. Thankfully the bearings are visible and easy to grease.
