global_odyssey
Last time at the boat I noticed our 4 year old Jabsco heads pump would hiss and whistle after it was flushed. I thought maybe we just needed a service kit to renew the seals.
Later, while talking to someone on the pontoon my wife appeared at the companionway and shouted that the heads bowl was nearly full.
Dismissively, I asked her to go and flush it then!
Next thing I knew, there was a sudden flow of (BROWN) water appeared from what turned out to be the holding tank vent at the top of the topsides. This came with a rather sh**ty aroma and was immediately followed by shouts of "STOP!".
To my embarrassment it appeared the holding tank vent was acting as an overflow!
How can this be? I'd pumped out the holding tank only the last time we used the boat. Surely we hadn't filled it up in just a weekend!? (it must be getting on for at least 10 gallons) and usually takes weeks.
Anyway, it appeared the tank was full and simply flushing more into it would send it out the vent, then it would drain back into the heads bowl due to the pressure.
My concern is how it filled up in the first place.
When the tank is emptied (via a large manual bilge pump) you can tell when it has run dry and the tank feels/sounds empty when you tap it.
Is there some way in which seawater is forcing its way into the holding tank when the boat is moving?
For safety we eptied the tank a little (on outgoing tide) to relieve the pressue. Both seacocks to outside are shut. I'm hoping ther bowl will not be full next time we go back to the boat!
If anyone has similar experiences and a solution, I'd like to know. We've only really started diverting regularly to the holding tank this season because we are in a marina.
<hr width=100% size=1>I've got wind......................
...............................in my sails!
