superheat6k
These are available to me at cost from the supplier / manufacturer and I know they are very reliable.My mistake. It seems that the T100 is 100k @ 25degC, so specific to this manufacturer. There are some advantages in using standard sensors which are easier to incorporate with a huge range of fitments.
I have bought a suitable plastic box enclosure with a clear lid for the PCBs. This will mount on a bulkhead within the engine bay. I am procuring the necessary hardware now.
For the flow I am considering putting a smaller flowswitch in the bleed line to the shaft seal, which takes off from the feed pipe between the gear oil and main coolers, but I will need to check for adequate flow at idle. However, if necessary I could build a logic loop preventing an alarm below a certain RPM. I can get a brass bodied switch for less than £10.
