pcatterall
I want to get my tanks and fuel clean for next season.
I have 2x 50 gallon tanks which are just connected by a pipe with a shut off valve.
There is only around 15 gallons in each tank at this time.
There is a large accessible inspection cover on each tank.
I propose to just scoop or pump out one tank into clear plastic containers ( the bottom couple of inches into a seperate container)
I will then clean and wipe out the empty tank.
When it is clean I will pour the settled fuel( after inspection) back in via a funnel with a fine mesh filter. ( I will take the containers home to let the fuel settle and decant as required)
I would then just repeat this on the other tank.
Clean water bowl change filters and ready to go! ??
Is this simple sounding process OK?
Any speciall tips on cleaning the tanks?
Anything I should do to to fuel before pouring back?
Should I add an anti bug treatment even if my fuel looks bug free?
Any other tips gratefully recieved
