pandos
I lost this season due to fuel system air leakage.
I did all of the normal things, that I have done on this boat many times previously and in addition to doing the same thing on dozens of pieces of machinery over the years but yet was unable to get it right.. my final thought was that it was a cracked pickup tube in the fuel tank allowing air and fluid to be sucked up, depending on the movement of the pickup pipe...
Having removed the pickup pipe it seems fine, so I am stumpted. There are two different threads on the banjo bolts used in the system and it may well be that some of these are mixed up and thereby damaging threads/seals.
I would like to rebuild the sytem with as few weaknesses as possible and add some gauges to show fuel pressure at the pump and vacuum to show if filters are getting blocked or if air is being drawn in ( I presume there is a happy medium which can be established where just fuel is being drawn through a clean filter)
I would also like to add a secondary supply, I have not really worked this out but I was thinking of a Valved tee in the suppply to the injection pump and feed this with a day-tank mounted above the engine which would be kept fed from a 12v inline pump, with a filter setup from a mitsubishi l200, simple spin on filter with built in bleeder pump.
Questions.
Has anyone used a replacement lift pump on an md21b, orbitrade make one for about €200.
There is a non return valve on the secondary filter housing to which is linked the return line from the highpressure pump.... what effect would removing this connection have ?, it seems to me to be a weakness...
attached is a pdf of the fuel system..any advice appreciated
Questions.
