pcatterall
The photo will hopefully show 3 fittings!!
I am getting together the items needed for my DIY fuel polishing kit ( I will not reveal my choice of filter head or element in case of severe thread drift!!)
As well as making up a polishing system I hope to gain a bit of expertise and knowledge about fuel systems generally so that I can overhaul the boat system which is in an untidy state. I also hope to be able to build up a 'repair kit' ( pipe fittings etc) so that I can carry out emergency repairs.
I need a lesson on fittings and hope that others may benefit.
In theory the 3 fittings shown could all be used to connect a pipe to a filter ( for example)
The Black pipe comes with an insert to stiffen the end.
2 of them are of the olive type and rely on the olive being held pressed against a seat whih I can see inside the filter head, the other relies on the washer to effect the seal.
Is one system better than the other?
Are there other situations where one would be used rather than the other?
One item is black plastic pipe with a thin (1mm) wall. I would not care to have that fitted on my boat but would an armoured version be suitable? I ask because that pipe with a variety of fittings having an 8mm tail and lots of jubillees would seem a good item to have in my emergency repair kit.
I will appreciate your advice on this.
