Boo2
Hi,
I bought a new fuel tank for my UFO 34 a while back but before getting it fitted I found the cockpit sole needed replacing. I've done that but it leaves me in a quandary because the old fuel filler location was in the middle of the cockpit sole which is the worst place possible from the point of view of contamination (see pic).
So my dilemma : where to site the new filler cap ?
The fuel tank sits directly below the cockpit sole, and, as you see from the pic, there is no space on the side decks beside the cockpit coaming to fit a new filler cap. I would rather not do that anyway because, as I understand it, there are regulations coming into play regarding the location of fuel fillers which require than any overspill stays inside the boat.
The stb cockpit seat does open but there is accommodation directly below. Abaft the stbd cockpit seat is the gas locker. The port cockpit seat opens to a locker (somewhat watertight to the rest of the hull). Abaft the port cockpit seat is the bilge pump (see second pic). The rear locker has space on either side that might work.
So, any ideas where to situate the best place to situate the new fuel filler ?
Thanks,
Boo2
Thanks,
Boo2
