geem
Our genoa is 65m2. I increased the main genoa winches from the original under sized Barlow none St to Lewmar 58STs. Its a game changer but sometimes wish I had gone bigger.I had 2 pairs of ST 30s on my Bavaria 33 with a 20sqm jib and a 60sqm cruising chute. The aft pair were close enough to the wheel such that I could short tack up and down the harbour. Left the handles in all the time and often in lighter airs I could get away without cranking at all, or only the last bit of trimming. Forward pair were used for the chute. Would not be without them - fortunately my latest boat came with ST 43s, way OTT and i might see if I can sell them and go down to 30s as genoa is around 25sqm
I just had the lewmar 43 Waveline spinnaker winches modified to ST jaws. The waveline jaws were worn out. In total we have 11 winches. Originally all none ST now 7 of the heavily used ones are ST. The spinnaker winch really doesn't need ST, nor the mainsail reefing winch or the mizzen staysail winch. The fifth winch on the main mast doesn't get used since I added jammers to the jib and genoa halyards. I can now use an ST winch to tension either halyard.
ST,winches are fantastic when you need them but not every winch needs them in my experience
