Fridge Engineer nr Fambridge
moonshine
20 Jun 2004
Essex, UK
Hi there,
Currently wrestling with non-functioning fridge.
Replaced the thermostat did not fix the problem, (took over 3 weeks to get the replacement, but that's another story). Compressor, Danfoss BD35F, does not start so need the charge level and the electronic unit checked out.
Any recommendations for fridge engineers nr Fambridge ?
Moonshine
Thanks for the pointer, Penguin, or 'fixmyfridge' has info on fault codes, just need some wire and a 10mA LED.
I had no idea the system was so complicated, the motor runs on 3 phase !!!
Still might need an engineer to check the charge :-(
Boat is not called Moonshine, naming ceremony last Sunday gave it the name of Three Farthings.
Fridge is fixed !
After much internet trawling I discovered some articles on Danfoss BD35F fault codes via a fitted LED. This indicated a major fault on either controller or compressor. Phoned Shoreline Sussex ended up ordering replacement controller £105 in del. They also can supply replacement compressors.
Climbed back in cupboard, connected up, and hurrah, all appears to be working again. Cold beers back on the menu.
It is interesting that I could not find any local refridgeration engineers knowledgeable in 12v systems ! For future reference, if anyone comes across one please advise.
Regards,
Moonshine
