duncan99210
Or at least not like it used to do...
First off, it's a pretty standard Danfoss compressor hooked up to a plate in the fridge compartment. When switched on, it used to happily hum away to itself for a few minutes, then shut down for a period before starting up again. Now, it still works fine for a time then gets into a pattern of starting up for a few seconds and then shutting down. Keeps doing that for a period (which can vary from five minutes to an hour or more) before suddenly deciding to start working again as it should.
The set up is 18 years old and I spent money on it three years back having a man refurbish it and fit a new plate, since when it has run fine until now. I'm reluctant to spend more money on a man coming out to fettle it and then have it die on me. So, before I have it put down and replace it, anyone any ideas on what might have gone wrong with it and is there a do it yourself fix? Oh, and I've cleaned the contacts where the electrical supply arrives at the compressor and the voltage reading as the compressor starts (or tries to) is well in excess of 12.7v.
