Freshwater system problem
Kelpie
15 May 2005
Afloat
Can anybody help me diagnose a problem with a freshwater system? There's a pump, a pressure switch, and an accumulator tank. Recently the pump has been failing to kick in, and I was finding that a wee wiggle of the pressure switch was generally sufficient to make it spring back into life. But the other day the opposite happened- the pump just began to run continuously, even though the tap was off.
Does this sound like I need a new pressure switch? I notice that there's a turny knob thing on it, might that be of help?
ffiill
5 Sep 2007
The pressure switch is adjusted by the knob.Turn the tap full on and operate the knob to see if it has any effect.
The real big problem I experience is because the pump spends months not in use the brushes in the electric motor stick.Sometimes all it needs is a good spin by hand and usually you can do that in situ by removing the pump body and accessing the drive spindle.
The other issue can be a leak in the system.Several years ago my pipes froze and split in a most obscure place.@
Len Ingalls
6 Dec 2014
N.B.,Canada
Sounds like points (contacts ) in P-Swx to me. Sandpaper if accessible. Replace P-Swx otherwise.
Another possibility- the P-Swx pressure sensing tube/passageway is blocked with corrosion crud.
Cheers/ Len
KellysEye
23 Jul 2006
Emsworth Hants
www.kellyseye.net
You might need to take the pump apart it could be the pressure switch, which I would replace, or a broken diaphragm. If it runs continuously turn it off quickly or the motor will burn out.
Kelpie
15 May 2005
Afloat
Cheers/ Len
Thanks, where would I find the contacts? I take it you don't mean the wires that connect the switch to the pump?
SandgroperWA
22 Feb 2010
Perth Aust. RPYC
I had the same problem. Cleaned and replaced the spade clips / electrical connectors. Drove me nuts. Failed just as I got in the shower, bought a complete new pump and switch. About $230 AUD. No dry showers any more! Keeps me and more importantly my girl happy.
