eagleswing
we have a jabsco freshwater par-max pump, #17050, 8.7 gallons/minute, multiple outlet. this weekend, I noticed that the pump did NOT shut off when the water tank was empty, but continued to run . we shut off the pump manually, we then filled the h 2 0 tank. we turned the pump on after giving it an overnite rest. now the pump makes its usual noise and runs, but instead of getting 8.7 GPM, we were at 1 teaspoon per minute and a lot of air hissing out of the faucet sink tap. the pump filter and inlet lines look clean and fine, the w ater tank is 1/2 full and is a gravity feed into the pump. this pump has a thermal overload switch on the motor which is an auto-reset , and also a pump pressure switch to shut off the pump if the water level is too low . (or nonexistent ) (as in , 'someone's ' shower accidentally drained the whole water tank and 'someone' forgot to shut the freshwater pump off despite there being no h 2 0 in the shower...) ...)
does anyone know whether a bad pressure switch will cause this pump behavior ? it's a 10 pound cost to replace the switch but a 100 pond cost to replace the whole pump...
any and all thoughts welcome...
