Fresh water tank breather
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
I am in the process of replacing a flexible water tank with a 'fixed' moulded tank. I will need to add a breather pipe to the setup. I am planning to run a 1/2" hose up to the cabin side and use a !/2" through hull with barb and a clam shell cover. Are there any better options than the through hull/clamshell combination?
My boat has as original equipment a small circular fitting with a fine gauze in the aperture facing down. It is maybe an inch across and inconspicuous, but I don’t know what it is called, ther than a vent.
Why do you need a breather? , when you fill it with water it will inflate and as you use it, it will deflate.
I think you have misinterpreted the original post. The OP has a flexible tank which he is replacing with a rigid one, hence the need for a breather.
Because he is switching to a non-flexible tank....
We changed our breathers so that they went into the bilge. That way we we don't have to worry about sea water intrusion, spiders clogging vent screens, etc.
Yes, I've got one of those on the diesel tank but I don't think it would be big enough to cope when filling the water tank. A bigger (1/2" pipe size) one would be ideal.
I had thought about that but the breather would be in the bows and I don't want overflow water running through the bilges to the stern.
On my freshwater tank I just located the 1/2" breather pipe behind the inside of the cabin liner as high as possible under the cabin roof.
No need to any external connection.
I also fitted a float switch in the top of the tank to indicate when the tank is fill of ensure the filler is below the upper level of the vent pipe for when the tank is full water will just overflow out of the deck filler
... when the tank is full water will just overflow out of the deck filler
That sounds like an option. I can only get the top of the breather about 6" above the filler, does the team think that would be enough to guarantee that nothing exits the breather if I leave the filler tap running for a bit too long?
I tried that and it overflowed via the breather !
I've fitted a hose connector to the end of the breather, the one with a 'stop lock'. Sits open until water hits it and then shuts. Needs to be in the upright position to work well. Can test it with a hose pipe at home.
Something like this -
https://www.screwfix.com/p/hozelock-12-5-15mm-single-end-female-aquastop-connector/66370
We had a fixed (aluminium?) tank under the double berth in the aft cabin, with a gauze breather outlet in the transom. A few years into our ownership, something got blocked and we never did manage to find or clear it. WE just had to fill the tank really slowly to avoid loud "clunking" noises and dramatic spouts of water back through the filler.
But the tank must be vented to allow air in as water is drawn out.
