MattK1969
Active Member
Hi, think my pressure switch has gone on my pump. Are these repairable or is it new pump time? Thanks from rainy Västervik. Matt
As above, most probably the microswitch but if the pressure switch is not repairable and the pump is still good then adding one of these will solve the problem Whale Pressure Switch 0.5" bore 12 & 24vHi, think my pressure switch has gone on my pump. Are these repairable or is it new pump time? Thanks from rainy Västervik. Matt
They are brilliant. Ours works very well indeedAs above, most probably the microswitch but if the pressure switch is not repairable and the pump is still good then adding one of these will solve the problem Whale Pressure Switch 0.5" bore 12 & 24v
