simon barefoot
No details, but apparently a French yacht, 2 POB, sinking 170miles off scilly. Too rough for merchant ships to help.
Hope some details show me wrong.
A sea king going 200 miles further than a S92? Only on the back of a lorry!
Oh it can go further . . . . It's the coming back it struggles with!
This is the first example of how the replacement of the Sea Kings has put lives in danger.
According to Wikipedia, the Sea King has a range of 1000km and the Sikorsky 92 has a range of 999km.
I'm not certain, but I thought the new helicopters (the large ones, they've bought two types for different bases) had longer range than the Seakings? Perhaps those Wikipedia figures are measured in different ways (with / without a reserve, etc) ? Or we have a variant with larger tanks (I'm sure there are lots of options) ?
I'm pretty sure the Sea Kings at Culdrose haven't been replaced yet.It's Cheminées Pousoulat, it was perviously rescued off the Azores after taking in water in the same race and they set off an ERPIB at that time. The MRCC report is interesting http://hmcoastguard.blogspot.co.uk
This is the first example of how the replacement of the Sea Kings has put lives in danger. The Sea Kings has a range of more than 200 miles more than their replacements, this would have allowed the helicopter to stay on station longer. If it was not for the Star Isfjord these men could have perished as a result of the decision not to keep the Sea
Specifications (S-92)[edit]
Data from Sikorsky S-92 specifications,[63] International Directory of Civil Aircraft[2]
General characteristics
Crew: 2 (pilot, co-pilot)
Capacity: 19 passengers
Length: 56 ft 2 in (17.10 m)
Rotor diameter: 56 ft 4 in (17.17 m)
Height: 15 ft 5 in (4.71 m)
Disc area: 2,492.3 ft² (231.54 m²)
Empty weight: 15,500 lb (7,030 kg)
Loaded weight: 26,500 lb (12,020 kg)
Max. takeoff weight: 26,500 lb (12,020 kg)
Powerplant: 2 × General Electric CT7-8A turboshaft, 2,520 shp (1,879 kW) each
Fuselage length: 56 ft 2 in (17.1 m)
Fuselage width: 17 ft 3 in (5.26 m)
Rotor systems: Main rotor has 4 blades. From the main gearbox a set of driveshafts connect to the tail gearbox to turn the 4-blade tail rotor.
Cabin dimensions: 20 ft long by 6.6 ft tall[64]
Performance
Maximum speed: 165 knots (190 mph, 306 km/h)
Cruise speed: 151 kn, 174 mph (280 km/h)
Range: 539 nmi (999 km)
Service ceiling: 14,000 ft (4,270 m)
Disc loading: 9.8 lb/ft² (48 kg/m²)
Power/mass: 0.23 hp/lb (0.38 W/kg)
Specifications (Sea King HAS.5)[edit]
Orthographically projected diagram of the SH-3 Sea King.
Data from Omnifarious Sea King[125]
Crew: Two to four, depending on the mission
Length: 55 ft 10 in[126] (17.02 m)
Rotor diameter: 62 ft 0 in (18.90 m)
Height: 16 ft 10 in (5.13 m)
Disc area: 3,020 ft² (280 m²)
Empty weight: 14,051 lb (6,387 kg)
Loaded weight: 21,000 lb (9,525 kg)
Max. takeoff weight: 21,400 lb (9,707 kg) (overload weight)
Powerplant: 2 × Rolls-Royce Gnome H1400-2 turboshafts, 1,660 shp (1,238 kW) each
Propellers: Five bladed rotor
Performance
Maximum speed: 129 mph (112 knots, 208 km/h) (max cruise at sea level)
Range: 764 mi (664 nmi, 1,230 km)
Rate of climb: 2,020 ft/min (10.3 m/s)
Well according to Wikipedia (I did check first before positing) the Sea King is shown as having a range of 764miles and the S92 as 539 miles. Perhaps the actual models in use are different specifications in which case I stand corrected.
