higler
Heres a puzzler for someone out there who knows these engines--they were originally used in the fiesta and escort cars until about 2000, maybe a little later. I have one of these in my boat that I bought and refurbed last year, the engine has only done 66 hours running but was laid up for four years when the previous owner moved to Spain. The hours are genuine as I have all the original paperwork from Lancing marine. I renewed the belts filters etc and had it running fine in the boat yard then launched last Monday took it steady then took it up to 2000 revs and then the alarm and oil light came on I shut down straight away on inspection found it had dumped all the engine oil out through the sump pump into the bilge. Refilled the oil and my friend put his foot on the pump while I took her on to the mooring not 500 yards away and it still managed to shoot out more, I have since had the engine out and stripped it down-- oil pressure relief valve is fine, no blocked breather pipes, oil delivery strainer clear, rings are not stuck--only thing being the rings on 1 piston were not properly staggered, the only fault I could find, so now im looking for answers and hopefully someone who may have had a similar problem. Norman.
