FORD DIESEL ENGINES
Jcorstorphine
19 Aug 2001
Scotland
I am converting a Ford 1.6 Diesel (ex Fiesta) to a marine unit but am not sure what to do with the vacuum pump which is run off the Camshaft. If I simply remove the entire unit, the piston which is actuated by the camshaft will leave an oilway hole free and thus loose oil pressure,
Any thoughts?
regards
John C.
leave vacuum pump in place. install reservoir and run large truck type horns form it. Great sound.
Strathglass
Fife
I have converted several 1.8 ford engines. You remove the vacum pump, fit an adaptor on its two mountings and run a oil return pipe from the adaptor to the sump. The adaptor is certainly available from Lancing Matine and is called a "Blanking cover for vacuum pump aparture" it cost £22 + VAT in 2000.
