For those
Flossdog
8 Oct 2006
West Wales
Wow! Truely amazing. I once built a 3.5" steam loco, 0-6-0 tank and that was fiddly enough for me. At the other end of the scale, I am a friend of the museum of internal fire which is local to me and they have lots of really massive internal combustion engines. www.internalfire.com
davidej
17 Nov 2004
West Mersea. north Essex
That confirms my view -that it isn't actually turning under its own power, probably a hidden eletric motor. Apart from the cam gearing, there doesn't seem to be a carburettor or fuel suppy.
Beautiful minature engineering, nevertheless
stuhaynes
25 Dec 2009
Yorkshire
www.best-camping-stoves.com
who have an interest in small engineering, or are in the middle of rebuilding an engine. watch with awe, Gordy.
http://wimp.com/tiniestengine/
Loved the video, and more than happy to show my age (if required). I remember the tale of the yanks who drilled a hole through a sewing needle and sent it to a UK establishment (a university I think) just to show off their engineering talents. We Brits, of course, threaded the bl**dy hole and returned it with a bolt in it! Anyone else remember this, or any other other pointless excercises.?
Back to the OP. I didn't notice any piston rings!!! :rolleyes:
misterg
31 Oct 2003
N. Wales
I wouldn't like to rate the chances of the first one revving very fast with that big, long crankshaft and only 2 main bearings...
This one makes a better noise (I guess it uses commercial top-ends):
Link
This guy is more obsessive:
Link
Both with running 12 cylinder engines!
Andy
Avocet
3 Jun 2001
Cumbria
Yes, it's running on compressed air. Don't think it was ever intended to run on any kind of fuel, although it does have twin water pumps and some sort of cooling manifold, but I don't think there's any way for coolant to flow round the cylinders.
Can't explain the valve timing though. I wonder if, (because it doesn't have a "compression" stroke, as such), whether it can get away with opening its valves twice as often as it needs to? The induction stroke is also the power stroke, I suppose?
misterg
31 Oct 2003
N. Wales
If it's running on compressed air, the inlet valve needs to open on the 'down stroke' to admit air and the exhaust needs to open on the 'up stroke' to let it out again - every revolution, hence the 1:1 gearing.
Andy
pampas
17 Jul 2003
Falmouth
personally I think its running on compressed air,but also think its really a refridgerator compressor, as one of the captions mentions refigaot or something likes that. Lovely engineering all the same, assume waste oil for all the running gear so its a demostration project?
