Refueler
It also affects all actually as Red is reduced in sulphur levels to follow Road white.
Contrary to some peoples thoughts Red Diesel is not poor quality - it's just blended to different specs often from similar stock to road grade. Presently it has a sulphur level of 0.1% or less. Road at 10ppm or less.
Let's take a boat tank that has happily been filled year after year with red from all and sundry. No matter what fuel - you will get build ups of sediments, crud and gums. Summer grade left in tanks over winter ... gum drops out ... parafins etc.
These all form a cake or crust in tank bottoms.
Come along changes and you start throwing white or low sulphur gasoil (diesel) in ... someone thinks .. Oh a bit of injector system cleaner as well - let's get rid of the remnants of red ...
Not long later and you start to notice engine performance falling off. You blame this bl**y change of diesel. That bl**y Refuelers sent cra* over again !
Look nearer home I'm afraid. And here I can talk from my own experience as well ! What happens is the change of diesel and cleaners / solvents etc. starts to lift that crust and it starts to block filters, because it can really break down fine - it also gets to your injection thimble filter. Thimble filter is a small thimble sized filter trap inside the main inlet of injection pump.
So take care and be sparing with system cleaners - they are simply solvents. If you have crud in tank bottom you may have to do like I had to - break it up and suck out with Pela or similar. Kerosine or gasoline is a good light solvent to help - but be careful with vapour etc. and really only use it to get last dregs ... flushing out with diesel as that will dilute the volatile gasoline / kero.
This is an advisory from the "Nigel cache of Useless Info Archive" ... /forums/images/graemlins/wink.gif
Good boating and hope your injectors stay clean !
