trapezeartist
I've seen many references to roller-furling genoas with a "foam luff". Apparently this improves the sail shape when the sail is well furled. How does that work? What does the foam luff consit of? Any pictures?
Thats dodgy advice since all sails when brand new have belly cut into them. If they didnt, they wouldnt work as an aerofoil. And if they have some belly, then as the sail is rolled up, this gets pushed more and more to the leach of the sail and you end up with a sail thats luffind at top and bottom and over full in the middle.
The problem is that as the sail ages and sags even more in the middle, the foam gets squashed and becomes less effective. So it needs replacing and increasing.
personally I'm not conviced about foam luffs cos the big bulk of rolled up sail messes up the genoa when it rolled anyway. Maybe better to save the dosh and put it towards a 100% yankee for use when the wind gets up.
A rope padded luff is better. I doesn't get as crushed as a foam one. A small pocket is sewn just aft of the luff rope and filled with, you guessed it, rope.
To get a well setting sail the use of laminate sailcloth and no UV strip helps enomously. I've used this arrangement sucessfully on two sails and I've just ordered a third.
Do you then use a sock to protect the sail as there is no UV strip?
Ted
In The Netherlands the use of sail socks is commonplace. The UV strip is a rarity over there. Perhaps they rate sail performance over convenience.
I tend to cover the sail with a sock as the rope padding makes it a bit bulky to flake easily and leaves no room in my fo'c'sle, which is like your cupboard under the stairs anyway!
How well -or badly, do folks find they can fully furl a padded luff sail.
I've seen old sails not furl very tightly, old sails furled like pencils, some newer laminate /padded luff sails furling smoothly - but not very neatly...
How much do you sacrifice in furled neatness / bulk for the value of the padding and partly reefed foresails?
