Spirit (of Glenans)
Has anyone ever filled a burst fender with expanding polyeurethane foam? If so was it successful?
Spirit: I've a suspicion that even if you could inject the raw foam satisfactorily, it wouldn't necessarily do what you hope. The foaming process is caused by a reaction with atmospheric moisture in which the inside of a fender may be deficient. In fact I dimly recall a fairly recent thread in which foam was injected into some sort of bag, with disappointing results.
I've certainly done that, but not to use it as a fender. Once the thing is full of foam, it will be completely hard and no use at all for fendering. My mooring buoy was mysteriously holed (any lasooers around here?), so I just cut a small hole in the top, and skooshed in builders foam. The excess comes out the hole.
You did better than me. I filled the roller of a Suffolk Colt with concrete. It weighed a ton but didn't half roll well.I haven't done a fender, BUT have filled the plastic "wheel" of my 40 year old Dyson Ballbarrow with foam. Works a treat! ��
