Andy Bav
Hi All,
We have quite a slow flow through the raw water side of the AC system. The inlet is furred up as she is due to be hauled out in 4 weeks time for her annual painting etc etc as the strainer had around 3 inches of mussels in it. The furthest unit away from the pump shows an HPF code every now and again…
If that doesn’t improve the flow, the constriction may be further upstream. Seems I have two options, one use a mousing cable to “rod” from unit end to outlet (through the exhaust water outlet into the sea), or alternatively rig up a “closed loop” circuit using a large bucket, a bilge pump and some connecting hoses. The question is what solution to circulate. In Spain they sell “aquaferte” which is basically hydrochloride acid, so am considering usig a diluted soltion of that…
Be interested if others have done something similar, and how you approached it. (Fairline Targa 52 2006)
NB we had 2 of the 3 units regassed a couple of months ago..
