Did a quick forum search but didn’t come up with anything. Does anyone use a flushing oil before an oil change? Any downside to using one or is it just snake flushing oil?
Not recommended by most car engine builders anymore. On a very dirty engine the high detergent content can dislodge deposits that can then block oilways.
I rebuilt a rover V8 that had been destroyed by crud from the valley between the banks getting into the oil pump. It had been run with flushing oil.
I would just change oil and filters regularly and use the best oil you can within the spec required.
I have only ever seen one firm use it, and that was because they ran their vans way past their normal oil change intervals, predictably they always had a van in for a new engine, and even then it was a cheap refurb which were so carp they quite often did not make it out the workshop door before failing!
I have only ever had to flush one engine that the oil hand congealed, and for that I used a pint of derv in the oil drove a few miles then changed it, that was many years ago and i still own the car.
A pint of derv before an oil change was also the trick to free up sticky hydraulic tappets, again this was over 20 years ago.
