petem
You blow up your lugger 250 bhp , worst case its a full rebuild at around 60k inc install but chances are it will be still going when you me and grand kids are dead.
Why so much?
I take on board what you say and there maybe an element of truth with regards to some LRMY in terms of their "Achilles heel" , but look around and you will find the likes of ORY offer in fact to many the perfect med cruising yacht. Take the 700 series, the flybridge is simply enormous compared to a 70 FB planning yacht., there is space for a 15' tender to go athwartships, four or five proper sun loungers forward of the that and then a huge area under the hard top that can accommodate 10 plus the skipper and two stidds along with a big alfresco galley with full sized BBQ, fridges , ice maker, sink, prep area and storage . Under the prow of the FB is a humougous space for deck chairs, tables, inflatable slides , toys , HT ladder and space to still crawl around in. On the fordeck there is pull out sunbed and space for 4 -5 free standing chairs and table and can be optioned with sun awning , Aft deck is pretty huge too, dining for 6 - 8 and if you option the aft galley layout a full sliding window reveals a cocktail bar area and seating . When is comes to internal space , the entire main deck is open plan and can be with a touch of button enclosed away form the pilothouse for night passage, there is a good sized day head on the main deck with internal access and also access from the side deck (how many planning production boats have that ?) , the galley is as big as your home kitchen with dishwasher , trash compactor, double domestic sized sinks, huge American side by side fridge freezer , five burner gas stove, 1 1/2 size oven and loads of counter space and even an Island unit for food preparation. Saloon has seating for 7 plus two recliners, pilothouse has another settee for 5 plus skipper . External and internal real estate is a lot more than a 70 FB P hull (which is actually usually only a 65' or less hull, they just add the over hangs and hydraulic platform dims to get the bigger LOA. where as the 70 LRMY is bang on a 70' moulded hull length .
And then there is the crew space on top of the four cabins, two crew cabins, crew heads and shower and then a crew galley and a workshop which then leads on into a full walk in stand up engine room big enough to play table tennis in.
How's my sales technique? or am I fired from YBW again
Why so much?
Why so much?
I did say my Achilles heel -comment was a generalisation, but certainly the interior spaces of the ORY you mention are impressive. Which ORY is it exactly, the 720 Classic? I was looking at the website but couldn't positively id the correct model from your pics, probably due to to degree of customisation.
The exterior renderings of the Trident 720 look pretty nice, btw.
I have no doubt that ORY are the among the best in terms of quality and equipment, etc. and even ahead of the competition in the genre in terms of living spaces acreage. Looking at the pics on the OR website (the fly on the 720, for instance), the spaces still feel less liveable than on comparable sized med P boats IMO. And that's fine of course, designed with a different brief.
My personal experience of this type of craft is of slightly smaller ones and I fully appreciate that every boat is a compromise in one way or another, and the smaller you go, the bigger the compromise.
Pete you best not think about it. Its not going to happen to you! FWIW I have been told that the rebuild cost for my MAN engines would be £100k + per side. As I say best not think about it
If you were looking at the 720 that is a skylounge model and therefore the flybridge is significantly reduced because you have another enclosed space with sofa, desk, bridge and heads on the upper deck. If you look at the 700 attached you can see the depth of the space aft to for'd .View attachment 67453View attachment 67454
I'm surprised to see an ORY buyer speccing teak on the f/b, I can't remember to have seen any others.If you look at the 700 attached you can see the depth of the space aft to for'd
??? The planks are not full length. There are joints.I'm surprised to see an ORY buyer speccing teak on the f/b, I can't remember to have seen any others.
In fact, I also would rather not have it, even assuming money no object. But each to their own, of course.
Just curious: am I right in seeing no seams at the planks junctions (presumably to give the appearance of single planks along the whole length)? It's hard to tell for sure from the pic...
Yup, the joints are visible, but they seem to be (though I'm not sure) teak against teak, without a seam in between.??? The planks are not full length. There are joints.
T, what are the gimballed white things in plastic bags? 4 each side. Boomtastic loudspeakers?
And why the blue decals on the crane? Custom request?
Cool boat!
Do you mean jointed with seams between the planks ends, or without?Must be the pic quality the planks are jointed.
Sorry if by chance the term "jointed" implies with seams, to my mind it doesn't, but I might well be wrong...
Btw, I can see the seams in the border planks surrounding the two GRP "cheeks" either side, but not in the rest of the floor.
And while we are at that, another curiosity, if I may: is the floor made with teak planks glued above plywood panels, or with single teak planks directly laid above the GRP deck?
You're well out of date T. The P plastic builders (FairPrinSeekFerretti et al) are using solid teak for the last several years, not thin teak on ply. No doubt your planks are thicker @ maybe 12mm+ whereas those mainstreamers are at 6/8mm to save cost and weight, but even 6mm solid is far far superior to teak veneer on plyNo thin teak on ply type of thing , we only use solid teak planks floated onto the deck . proper job , you can pane down the teak loads of times over the years and never hit the deck .
The P boat builders in general use a very thin teak almost a veneer in some cases glued down to plywood and then stuck to the deck , then use solid bullnose on areas the leading edge of steps etc to give the effect of solid teak. Looks fine until the ply starts rot or there are little ingresses of water and the whole thing starts to lift , or you need to sand the decks and discover you just sanded a bit too much and are through to the plywood and then the whole lot has to come up.
It's another reason you pay a higher price for a custom SD , laying solid teak by hand and the proper way is much more expensive than buying in sheets of 8X4 pre manufactured teak panels .
No way - there is black caulk in those joints!Yup, the joints are visible, but they seem to be (though I'm not sure) teak against teak, without a seam in between.
Hence my question.
She looks at home I think . Very happy to be there for our winter jobs.
The giveaway is the grain direction T. If it's a big sheet of veneered ply with cnc cut grooves for faux caulk, some margin planks will have the grain going across then not longways, urgh!Your right J, Fair/prin/squeaker et al do use solid, but the cheapo producers are still using skiny stuff on ply , you can see cus the bullnose is completely different finish and look to the decks , even the caulking is faux .
